Ir para o conteúdo principal
The first generation Honda CRV, produced from 1995 to 2001.
cant get tailgate door unlocked
I understand there is a sequence to set the door locks. Right now I can't get the tailgate door open. My drivers side door is open and other 3 doors and tailgate are locked. How do i reset so all are unlocked?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
sblankford , Info supplied by autotalk link below.
Enter the car and close all doors.
Each of the following steps must be completed within five seconds of completing the previous step. If you take longer or make a mistake, start the entire procedure over again.
Insert the key into the ignition, and hold one remote in your left hand. Whenever the instructions say to press the LOCK button, you should press the lock button on the remote for about a second and then release it.
Perform each of the following three steps in order, then repeat all three steps two more times, for a total of three times each:
1. Turn the ignition switch to the ON position, marked II.
2. Press the LOCK button.
3. Turn the ignition switch to the Off position, marked I.
Do this three times!
Next, turn the ignition switch to the ON position (II) for a fourth time.
Press the LOCK button again. The door locks should now make a cycling sound, indicating that the system has entered Programming Mode.
Press the LOCK button one more time to program this remote. If you have other remotes to program, press the LOCK button on each one in turn. The door locks should make the cycling sound after you press LOCK on each remote. You may program up to three remotes, and they must all be programmed within ten seconds of each other.
Turn the ignition off and remove the key. The remotes are now programmed and may be tested.
If you’ve got a trunk/hatch release, hold the button for this function for a few seconds.
More, key fob resetting procedures can be found at the links below for the CRV. Good luck.
http://www.autotalk.com/honda-cr-v-97-04...
http://www.crvownersclub.com/forums/14-p...
http://www.doityourself.com/forum/passen...
Esta resposta foi útil?
Pontuação 2
Place the key into ignition then turn. it to the on position right before you full turn the engine on, when the key is in the on position hold down the unlock door button for 5seconds till you here two clicks after the first sounding primary click. keep holding after u hear the two clicks until you hear another click. after the third click turn car key to off. then turn back to on after 3second in off and all doors should open.
Pontuação 0
1 comentário:
I did exactly following your instructions and it seems that it took about a couple of minutes to start working but it did. At first the button on the tailgate didn't work but then all of a sudden everything started working. Thank you very much.
por
Adicionar a sua resposta
sblankford será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 31
Ao todo: 6,880
