Ir para o conteúdo principal
Released in 2012, this laptop features a Core i7 processor, dedicated Nvidia 620M GPU, and a 1080p display.
27 Perguntas Visualizar todos
Upgrade only cpu or any motherboard?
Hi, I've got this wonderfull notebook with cpu i5 and for this reason I want upgrade it for lengthen its life. So I decided to upgrade the cpu, and I found the mothebord with i7, but is it possible upgrade only cpu, same generation?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
The teardown for the laptop is here in iFixit.
Asus Zenbook UX32VD Teardown
The CPU/GPU is soldered on. While it can be changed, you will have to have some expensive equipment with some incredibly good soldering skills and a lot of patience.
How to replace glued CPU / GPU
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
deltaf será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 1,355
