Can it be hooked to a hard drive
I want to hook a external hard drive to the next book will it let me do this
Esta é uma boa pergunta?
Yes...WD Passport 1 TB external hard drive...for windows
Esta resposta foi útil?
James --
There are a couple of issues here: connectivity & power.
The Nextbook needs to provide enough power for whatever device you connect. Simplest test for this is to use a USB flash drive since they require little power. For a larger device, be sure the Nextbook is plugged in charging mode to provide the most power.
Next: What is the Operating System of your Nextbook?
Good luck,
Russ
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 1,644
2 comentários
Best way to find out is to just try it. Connect a USB drive, power up and see if it recognizes it.
por Russ Walden
Has anyone replaced the internal 32GB with more storage,or is it hardwired?
por Igor Schmidlapp
