Ir para o conteúdo principal
Brightness can be set only on low setting
Hello community,
I have a Thunderbolt Display which was used with my Macbook Pro (Windows 8.1 via Boot Camp). 2 days ago it made a clicking sound and the picture went dark on the Windows OS. After that I took the Monitor home and tested it with my Macbook Pro at home (OS Sierra). I can set the brightness in the Apple OS but only from Dark - 1 -2 Points (using ctrl + f2), when I go on the next one (Number 3) it doesn´t get brighter and the picture starts to flicker. All the next brightness Settings do not change the flickering or get brighter.
Installed the Firmware 1.2 - didn´t do any change.
Maybe someone had a similar issue...
Thanks in advance!
Nejc
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I lifted the LCD Pannel, checked all the Connections (couldn´t see any problems). Left it alone for 3 days. After that it started working as usual again....
por
Did the issue ever come back?
por
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like something went screwy with the power regulator that feeds the backlight.
Esta resposta foi útil?
Pontuação 0
3 comentários:
Well after I unplugged the Monitor it showed the same symptoms... Can I somehow repair the power regulator for the backlight? Or do I have to change it?
por
Have a similar issue. If display brightness is set to above 70% after several minutes of use the screen goes black. Works totally fine if the brightness is below 70% (approximately). Replaced the power supply and tried a separate TB cable neither helped resolve the issue.
por
Hi Guys, having similar Issue. TBD flashing sometimes and later blackouts. When i lower the brightness it seems to work ok. Did you find out anything about the hardware or software driven reason of this problem? cheers!
por
Adicionar a sua resposta
Nejc Sitar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 674
