Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Why are there only lines on screen?
I just carefully replaced the digitizer screen on the iPad Mini2. After reassembly there are only lines on screen (see attached image).
1.I unplugged the battery first during disassembly
2.All wires and contacts that were "covered" are covered
Anyone have any ideas what I did wrong?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Ipad Minis are challenging, the circle in the bottom right hand corner is a broken lcd and will have to be replaced again. : (
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
juricta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 586
