Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Ghost clicks after 3 minutes of usage
On my iPhone 5s, to works perfect for first 3/4 minutes of usage.
Then it seddeny starts doing ghost clicks and non responsive.
(I also see some vertical lines on display)
Then I lock the device (turn off display), wait for 2 min Aprox. Unlock again and it works perfectly for next 2/3 minutes.
As the cycle goes on.
Is this a genuine bug or specially granted to me?
How can I fx it?
Already tried
Reset
Restore
Reboots
Re-fixing display and touch strips.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
It more than likely sounds you received a faulty screen, or you may have damaged it installing it.
Try another screen and see if that resolves your issue, as there is a lot of garbage being sold on the likes of eBay etc. :-)
Esta resposta foi útil?
Pontuação 1
I recently had a similar issue on my iPhone 5. The glass had separated some from the LCD and dust had gotten in there. It would open apps, type gibberish in text messages, etc. Replacing the display assembly fixed it.
iPhone 5s Screen Replacement
Pontuação 1
Adicionar a sua resposta
Mehran será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 98
