Ir para o conteúdo principal
Quad Core 9 inch Android enabled Tablet, released October 2014, identified by model number ME-9Q
Why my table would not turn on
tablet won power up and lights dont come on
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
How This Problem Start ?
por
Adicionar um comentário
1 resposta
First step is does your power supply or device have a power indicator Lots don't. Have you tested the power cable on another device. usually tablet power connectors are mini or micro USB so you can try another phone cable or USB power adaptor on your tablet also it might not have as much power but it will trickle charges
If screen glitches and this only when power button is pressed would indicate low power
Also check non of the USB or HDMI pins are touching on device as can cause tablet to also cut out
Sometimes simple things cause complicated problems
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
sean m joseph será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 281
