Ir para o conteúdo principal
The Asus X53E is a 15.6-inch Windows laptop released by Asus in 2011.
15 Perguntas Visualizar todos
Bios animation start problem
Ive started my bios , configured stuff one by one restart after restart , then i clicked bios animated start and after saving changes and restart i get black screen , how to fix this for this model
Esta é uma boa pergunta?
Pontuação 1
1 comentário
you cant go back to bios Menu ? Or just seeing black screen ?
por
Adicionar um comentário
2 respostas
Solução escolhida
Make power is off.
Remove battery.
Press power button for about 10 seconds.
Put battery back in laptop.
Press and hold the F2 button  , then press the power button.
DO NOT RELEASE the F2 button   until the BIOS screen display.
Reverse that last BIOS setting you change - you don’t say what it was.
Esta resposta foi útil?
Pontuação 1
If you have black screen and you can't do anything, you should try reset BIOS. If it still doesn't work, there is probably one way to repair it - flashing BIOS.
Pontuação 0
1 comentário:
I'm not such an skilled when it involves this just look at: https://creabiz.co/
por
Adicionar a sua resposta
mdestas1995 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 513
