Ir para o conteúdo principal
Improved second generation Google-branded tablet with a 7" screen.
20 Perguntas Visualizar todos
My tablet bricked and freezes at unlock bootloader
I was wondering since my Nexus 7 2nd edition will not let me try to unlock the bootloader with Nexus Root Toolkit because it gets to the unlock bootloader and freezes if I replaced my motherboard would that potentially fix the issue? Or can another hardware part be bought to fix this or do I have a fancy paperweight now?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
changing the motherboard is basically buying a new tablet. the part that the os is on that is most likely keeping you from doing anything though is the storage or hard drive. that is the hardware component that holds your os and all of your apps. I hope that this helps and that you no longer have a fancy paperweight
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Nick será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 354
