Ir para o conteúdo principal
The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
How Do I Fix The Red Screen of Death?
My samsung galaxy s4 that I am currently trying to repair for a friend has the red screen of death. It only displays samsung logo with red background, lines sort of flicker accounts the screen too. When put into recovery mode, it just goes black. I tried to mirror the prompts from another phone with no luck.
How can I reset the samsung and get rid of red screen of death?
Thanks!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Does Odin download mode work properly?
When phone is off hold power and volume down to get to the download mode booting.
Esta resposta foi útil?
Pontuação 2
4 comentários:
yes what does the down button do compared to the up button? It does come up with downloading target but still has red screen of death?
por
That's really bad news then. I think it is an issue with the nand flash memory chip on the logic board of the phone that has gone bad.
The download prompt menu prompts you to either go to download mode which is used to reflash firmware on a Samsung phone.
The other is to reboot from download mode if you pressed that hardware combination by accident.
Definitely worth a try reflashing Samsung firmware on that phone. You can use Samsung smart switch to reflash the ssytem software on the phone when it is in download mode.
por
im not sure how to do this, because when it comes up with downloading target it will stay on that screen forever, un responsive.. how exactly do I reset it pls?
por
And then he Never Gets An Answer. People with the necessary skills to troubleshoot the problems an end user without unlimited funds to call in a professional every time they forget their password is likely to encounter, should be cognizant that sometimes what seems self evident may not be as obvious to the average Joe trying to keep up. It may take a minute to figure out the appropriate questions. Giving half a treasure map - even one with really good instructions- is the same as giving no map at all. If the poor muggle is lucky. Well I'm off to find my answers elsewhere. Today's lesson? "Solved" as an operator may not function as it should. Sigh....
por
Adicionar a sua resposta
ZsTech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 21
Ao todo: 8,875
