Ir para o conteúdo principal
2.26 or 2.4 GHz / White plastic unibody enclosure
I need some help
Hi,
I bought that ssd, but mac doesn't still charging and I don't see a finish. I checked the verbose mode and the mac stay it freeze.
I have a Macbook7,1 white unibody Mid 2010 A1342.
Thank You
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Please clarify whats happening. Your system is not charging? Or won't run?
por
The system won't run using the sata port inside the mac.
por
Have you tried installing an OS on the SSD?
por
The ssd has installed Sierra, I installed the system on the ssd by using the usb port and I changed the original HDD for the new ssd, but is not working when I made change.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Most likely is that the new drive is not backward compatible with your machine.
Your machine has a Serial ATA (3 Gb/s) BUS.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you so much, I thought this would be the problem. Do you mind tell me what ssd could be compatible?
por
This guide gives links in the lower right hand side to drives that will work:
MacBook Unibody Model A1342 Hard Drive Replacement
por
Adicionar a sua resposta
Francisco Torres será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 107
