Ir para o conteúdo principal
Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
87 Perguntas Visualizar todos
cannot find any radio codes
i have a older Honda Accord [1996] the battery has been disconnected. cannot find any radio codes
Esta é uma boa pergunta?
Pontuação 0
1 comentário
You can get a radio code here: https://radiocodevault.com/honda
por
Adicionar um comentário
5 respostas
Solução escolhida
Donny Armstrong , Remove radio at least partially so you can get the serial #, normally on a white tag. Write down the serial # or take a pic., now with your ownership in hand and serial # of radio you can drive to the Honda dealer, provide proof of ownership, give them the numbers, and get your code. You can also contact Honda at links below and hopefully they can email you a code if given all required info.. 1st link shows how to remove radio, 2nd and 3rd link is where you can contact Honda. Good luck.
https://www.youtube.com/watch?v=3hW5eM5F...
https://radio-navicode.honda.com/
http://owners.honda.com/ownership/dealer...
Esta resposta foi útil?
Pontuação 1
2 comentários:
thanks alot for the info couldnt do it alone.
por
Donny, happy to be of assistance, good luck.
por
Pergunta mais útil
You can get a radio code here: https://radiocodevault.com/honda/
Hope it helps mate
Pontuação 2
If you can take out the radio and get the device serial number, you can look it up online at the site below. You will also need your VIN.
Pontuação 0
Hello, I think you should read the guide over at the below website, it will explain how you can get a radio code for your 1996 Honda Accord for free, give it a try. I've used it on both mine and my wifes Hondas and it worked perfectly both times. Beats paying the ridiculous fee at the main honda dealer!
http://www.freeradiounlocking.com/brands...
Pontuação 0
94 honda accord radio serial number 146035 the code number is 52652
Pontuação 0
1 comentário:
What about a 1995 Honda Civic coupe ex
por
Adicionar a sua resposta
Donny Armstrong será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 21
Últimos 30 dias: 114
Duração total: 11,300
