power windows not working
both front windows do not go up or down already tried switch and fuse
Esta é uma boa pergunta?
helgersonc, If equipped with some kind of child lock out control for windows check that the switch is in the correct position. If you have already eliminated the switches and fuses by testing, check for power to the switch. There is a good chance the wire harness that runs through the door jamb and door frame has become damaged. Take the protective wrap off in this area and check for pinched/damaged/broken wires.
Find below a couple links showing troubleshooting power windows. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 3,513
1 comentário
Have you tested the switches for the windows in question with a multimeter to see if you are getting 12V DC at the switch when the ignition is turned to run/accessory?
por Geoff Ice
