Ir para o conteúdo principal
Why would the drivers side heated seat not work?
The drivers side heated seat does not work but the passenger side heated seat does work, any ideas?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Try replacing the fuse.
The seat fuse should be in the Center Instrument Panel Utility Block The center instrument panel utility block is located
underneath the instrument panel, to the left of the
steering column. The seat fuse will be labeled HTD ST
There should be a couple of spares in the box. Check for the correct amperage.
Esta resposta foi útil?
Pontuação 2
Check the fuse.
Pontuação 1
Some cars, Buick for example, have separate control modules for each front seat. It's an easy check for your dealer to perform.
Pontuação 1
Adicionar a sua resposta
meyersteve será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 5,488
