My tablet will not turn on or charge
My tablet will not charge an does not show charging icon so there fore will not turn on at all as it ran completely flat
Esta é uma boa pergunta?
Esta resposta foi útil?
Plug one of these to your charger
if you see the battery charging then there are some other issues. bad battery, bad cable or broken charge port. USB Ameter.
Not always there are 4 wires connecting the battery, and if you pry it off sometimes you can break a lead this is what is causing mine not to charge after opening it, and there is no fix other then sending it to samsung, it takes some microsoldering.......and no one in the area does it....
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 1,112
