Ir para o conteúdo principal
Guias de reparo e desmontagem para micro-ondas da Kenmore.
Power pad not working
The buttons most work for timer but the start button stopped working can it be fixed
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@rayleewhite what model is your microwave and what have you tried?
por
kenmore the button enter stopped working
por
Adicionar um comentário
1 resposta
Solução escolhida
Cause 1
Touchpad and Control Panel
To determine if the touchpad and control panel are defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad and control panel.
Cause 2
Touchpad
To determine if the touchpad is defective, try pressing each of the buttons on the control panel. If some of the buttons respond correctly while others don’t, replace the touchpad.
Cause 3
User Control and Display Board
To determine if the control and display board is defective, try pressing each of the buttons on the control panel. If none of the buttons are responding correctly, replace the user control and display board.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Raymond White será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 27
Ao todo: 2,014
