Ir para o conteúdo principal
Announced on September 9, 2015, the iPad Mini 4 maintains the power of an iPad Air 2 in a smaller form factor.
173 Perguntas Visualizar todos
Sleep button not working
Hello there,
Just got an weird issue , i repaired an ipad mini 4th gen. everything works well except the sleep button wont work.
but it does work as power on/off .
i Know what most gone say now:
Bad digitizer , Nope tried 3 screens
tested screens on other ipad mini 4 and their it does work.
any had this problem to?
would love to hear how you solved this.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Transfer the Hall effect sensor, it's a small component near the home button. Without the sensor the machine asserts the cover signal as attached so the sleep/wake function is completely latched. The power button cannot be used for sleep/wake in this situation, only power off works.
Esta resposta foi útil?
Pontuação 2
2 comentários:
is there guide for that? How is it done?
por
i know what you mean , but what if you trow it away already? can it be ordered ?
por
Adicionar a sua resposta
briiangullentops será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,203
