Ir para o conteúdo principal
Part of Nokia's Lumia line of Windows smartphones. Announced July 2013.
could not restart, always showing error or dead battery
could not restart, always showing error. want to know what to do to so that my lumia 625 can function well, it couldn't restart or charge
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@mazu , John, I take it you are inquiring about the Nokia Lumia 625. It very well could be a faulty battery or connection. Below, the 1st link is a guide for changing the battery which can be used to enable the reseating of the connection first to see if that helps. the 2nd link is a replacement battery which you can also do a search on for better pricing perhaps. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Nokia Lumia 625 Battery Replacement
https://www.aliexpress.com/item/100-Orig...
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
john mazur será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 259
