iPhone 6S Proximity sensor issues
I have replaced many, many iPhone 6S screens with no issues. Tested everything pre and post replacement and everything is working fine. All of a sudden, the last 5-7 replacements ive had issues with the proximity sensors after the replacements. I have got to the point where I have been ordering extras to keep in stock for the replacement. Obviously this isnt a cost efficient method. I have tried different things on each replacement to see if it fixes the issue. Non have worked.
I get two different problems at different times. The first problem I tend to get, is the proximity sensor doesn't turn the screen black during calls. So you think a simple reseating would work? No. I try everything, including removing the plastic guide and trying to align it perfectly without it. Had to replace the sensor.
The second issue I tend to get now, is that the phone actually shuts off about 5-8 seconds into a phone call and resets. It is definitely an issue with the earpiece/proximity sensor, because if i test the phone with the headphones plugged in, or its set up through bluetooth, the phone works as it should. Also, had to replace the sensor.
Is anyone else having any issues like this, or am I the only one, and what are you finding to solve the issues? Luckily the last 3 were 6s's that I bought cracked to replace myself, but this last one I had an issue with the phone not turning black during call, So I reset the network settings and now its doing the reset thing 5-8 seconds into calls.
Esta é uma boa pergunta?
3 comentários
Have you tried the old screens back? Did you start using some new batch of screens?
por Rany
are you using metal tweezers?
por Josh W
I use both and have no issues.
Because I always pry at the diagonal part of the front camera flex behind it to lift up near proximity sensor first then use a metal or plastic spudger to lift up the front microphone flex via the top left side starting from where the cable lifts up.
por Ben
