Ir para o conteúdo principal
The Dell Inspiron 15-7537 is a 15.6" touchscreen laptop with an i5 core processor.
21 Perguntas Visualizar todos
Can the Ethernet port be replaced?
Hi team! I left my laptop at the office and some jerk dropped it! The matter is that it was connected to a short Ethernet cable and my jack ripped of as it fell down! Thankfully the laptop is working absolutely fine but is there a way to just change the Ethernet port or do I need to replace the entire mother board!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi. Better you use USB TO ETHERNET ADAPTER ($15 or lower). plug it in the usb ports you are not so bussy with when you need it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jack será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,010
