Ir para o conteúdo principal
Model A1213 / 8, 16, or 32 GB capacity
216 Perguntas Visualizar todos
Contacts with iTunes but I can not reset error (1)
Hi I tried to use my old iPod 1 generation I didn't use for years.
I can connect it with iTunes but can't reset. I always get the error (1)
Has anybody a good idea?
I would be thankful.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Search and download iTunes 11.0 (for some reason this version was able to connect with server and restore my ipod)
Uninstall your iTunes make sure all files are erased if you don't the Library from the latest version of iTunes will prevent the older version from starting.
Once 11.0 is running, restore iPod Touch as normal
I did mine from a PC and it worked.
Esta resposta foi útil?
Pontuação 1
2 comentários:
love you man... its 4:10 morning and after 4 days im finally relaxed i did it.... thanks thanks so so much....
por
No worries... I felt the same when it worked for me too. All the best
por
If you just want to wipe it, you can do it from the iPod itself:
-Settings
-General
-Reset
It might not reset through iTunes if it was attached to another computer/Apple account
Pontuação 0
Adicionar a sua resposta
Willsky será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 269
