Battery won't go past 3% and no charger light
I have a MacBook Air a1304, 2.13ghz and it has 2 problems.
1: the charger light does not come on, but it does charge.
2:the battery never got past 3%, it runs fine but doesn't go past that.
When I was taking it apart I chipped off a capacitor, it was something like c2555 or c3555 or like that. Could this be related?
Other than that, it works fine. All it needs is a hard drive and a LCD bezel and it will work.
it's charging with a power of 0.9 watts... That's probibly not normal.
Esta é uma boa pergunta?
5 comentários
Could you try running the Apple Hardware Test following the instructions here: https://support.apple.com/en-nz/HT201257 ? Preform the test with your charger connected, and let us know of the outcome. Thanks
por Patrick
How do I do that? I don't have the hdd and it was running a Ubuntu live cd.
por Gigabit87898
Turn the device off. Disconnect all devices other than the charger. Turn on your mac then immediately hold down the D key. Keep holding this key until you see a pixelized image of a computer. When this appears release the key and select your language. Select "Perform extended testing" then press return to start the test. It's all explained in the Apple Article I linked above.
por Patrick
@gigabit87898 please let us know the boardview number for this. Did you try an SMC reset and test battery?
por Reece
@reecee its 820-2375-A and I tried smc reset, new battery, etc. also the component was c5550
por Gigabit87898
