Why my wifi won't activate?
My phone wifi won't activate and I allready firewire it with odin and a factory rest after that, is there anything I can do?
Esta é uma boa pergunta?
Are you using a custom firmware? If so that could possibly do it. Other than that if it isn't turning on and you've tried a factory reset and you've re-flashed the phone then it could possibly be a chip in the phone that either needs re-soldered or replaced. Might be best to have a repair shop look at it. Same goes with the bluetooth. Wifi and bluetooth commonly share a chip inside the phone in Samsung phones.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 23
Ao todo: 391
Did you falsh it to stock rom or any custom rom? In some custom roms the Wifi is not working, usually is writen under "doesn't work"
por Claes
