Ir para o conteúdo principal
This is a, 35.70 cm (L) x 25.70 cm (W) x 2.54 cm (min H) / 3.96 cm (max H), notebook PC the unit weighs 6.6 lbs. It was released in 2006 and comes standard with a 80 GB hard drive.
need to change user name
how do I change user name ? cant remember old user name. please help. thanks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Whats your operating system? XP? If so, go to control panel,then user accts... click on the name you want changed. Options there willl show you. In fact, if memory serves you may also right click on the name to be changed, a menu will pop up with rename as one of the options.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
charlesbarber43 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 85
