Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
How to fix dented iPhone corners?
I have an iPhone 5s screen which was dropped and the screen was shattered. The phone was dropped on the top corner and is now dented slightly inwards, this is causing a problem when trying to replace the screen as it isn't sitting properly in the frame. I don't want to force it in as I don't want to break the new glass. Are there any suggested methods to re corner the frame?
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
You could see if a local store has a tool in stock called a gtool. This is used to bend out dented frames.
Or you could shave down the dent with a metal flathead screwdriver.
por
Adicionar um comentário
2 respostas
You could always buy an new chassis for the phone. They can be a little pricey but also allows you to customize the phone with a wide selection of colors. Check out iphone4parts.com. I will post the link that goes directly the part your phone uses.
http://iphone4parts.com/shop/iphone-chas...
Here is one much cheaper on ebay.
http://www.ebay.com/itm/New-Space-Gray-i...
Alternately, you could search for other bezels or chassis on ebay.com, amazon.com and also aliexpress.com.
Esta resposta foi útil?
Pontuação 0
This tool works great on iphone and ipad corners https://youtu.be/pea1NOk2UKQ
Pontuação 0
Adicionar a sua resposta
Stelios Sgoutas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 9,724
