Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Perguntas Visualizar todos
My battery will not charge
I replaced the battery on my MacBook A 1278 about a month ago, and it will not charge now. When it is plugged in I get a green light on my charger but it does not charge the battery and when the charger is unplugged the computer shuts off. Is there a fix for this or would I just have to purchase another battery?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Please go here and select your exact machine. There are 12 different A1278 machines. http://www.everymac.com/ultimate-mac-loo...
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Next go here and download and run Coconut Battery and let us know your results
http://www.coconut-flavour.com/coconutba...
Esta resposta foi útil?
Pontuação 2
3 comentários:
Sorry about that, it is a late 2008 A1278 2 GHz 2 core DuO Unibody.
The report says, Current Charge 0mA, Max Charge 0mA, Design Charge 0mA, status poor, and 4 load cycles.
por
Did this new battery ever charge? Do you still have the old one, if so put it in and run Coconut battery.
por
I have the same problem after 6 cycles. Capacity is 66% of the reference capacity.
I don't understand
por
There is a known problem with an ic chip on the logic board on the 2.0 Ghz version of these MacBooks. It will run from a charged battery, but will not charge the battery itself.
Pontuação 0
1 comentário:
Ok but how to repair ?
por
Adicionar a sua resposta
Thomas Batchelder será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 229
