Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
Exchange keyboard key hinge
Hi,
I had the P key stuck a bit and I tried to pry underneath it to remove some dirt. However I accidentally removed it and the hinge at the bottom side (where the key is hooked in) broke. I tried to remove the hinge to take a close look, but it looks like it is covered by the plastic of the key cap. I did not go further, but does anyone know, if the cap is glued and how one can remove it gently to reach and change the hinge?
The key still works fine, it just pops out at the bottom.
Thanks,
Duc
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You likely broke the key cap. I would take the system into an Apple Store and let them fix it. It should be still under warranty I wouldn't tell them what happened ;-}
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Duc Bao Ta será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 698
