Ir para o conteúdo principal
The fourth-generation Hyundai Elantra was released in 2006 for the 2007 model year. The Hyundai Elantra sold under the name Hyundai Avante in its South Korean home market.
2008 elantra door motor replace/repair
so my passenger side window is all geeeehhhahn and goes like the setting is on turtle so I think it might be time to learn how to replace it ie; how to take the door off and how to not kill myself removing the motor and how to put the door back on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Try this:
https://www.youtube.com/watch?v=Nsdf7nBo...
Esta resposta foi útil?
Pontuação 1
sebastian.moore2992 , Before you go to all the trouble of changing the motor, buy a spray can of silicone spray and liberally spray the rubber channel the widow runs up and down in(see 1st link). A lot of times the rubber gets very dry from usage and window is not permitted to slide easily. The 2nd link below show's how to remove the power window regulator and motor in an 2006, you will not have to remove the regulator if not damaged as the motor can be purchased separately. Good luck.
https://www.youtube.com/watch?v=nJPeMpGz...
Pontuação 1
Adicionar a sua resposta
sebastian.moore2992 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 237
