Ir para o conteúdo principal
The first generation Honda CRV, produced from 1995 to 2001.
Windshield wiper driver side doesn't work
Drivers side wiper doesn't work. Passenger side works fine
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@infamlaw , Cindy, the wiper arm retaining nut may of come loose or stripped. Use the link #1 below to see how to tighten the wiper arm nut, if nut appears to be tight, most likely the arms connection/boss is stripped and the arm will need replaced, Link#2 shows how. Link #3 shows one of many places available to get a new wiper arm. Good luck.
http://www.wikihow.com/Tighten-a-Windshi...
https://www.youtube.com/watch?v=qPC2n7ac...
http://www.carparts.com/honda/wiper-arm
Esta resposta foi útil?
Pontuação 4
2 comentários:
The nut was loose! Thank you!
por
@infamlaw , Cindy, thanks for replying back, glad I was of help. If it does happen to work loose in the future you may have to put a little loctite(thread locker) on the threads. Have a good week end.
por
Adicionar a sua resposta
Cindy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 897
