Why does it say error (11)
Esta é uma boa pergunta?
Error 11 is due to a disconnected motor. With an early production run of Bebops, some had issues with motors not being fully connected. Cables are just either unplugged or the snapped and broke. You can either contact Parrot about this or (riskier) attempt to disassemble the drone yourself on whichever motor may be out and fix the cable yourself.
Esta resposta foi útil?
It's something else. Because I run all motor separately with a single esc an it works well no problem I think these hands over the prop safety feature causes this to happen if there is a way on the main board that u can discount the features it would work fauless
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 182
Ao todo: 6,404
I checked all my wires and it still didn't work any other causes for error code 11 for the bebop 2?
por cast
