Ir para o conteúdo principal
Repair information and disassembly guides for pressure cookers.
Opening pressure cooker to replace LED board? How?
I need to replace the LED PCBoard on my electric pressure cooker as the LED display is broken. I managed to get the spare part from an appliance spares place, but now I have no idea where to open the Pressure cooker (easiest way), to swop out the old board for the new one. PLEASE HELP :-) - Cuisinart Electric Pressure Cooker CPC-600 or AEG/Electrolux EPC600.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Where did you get the LED board?
Thanks!
por
Adicionar um comentário
2 respostas
Solução escolhida
I just can't find any teardowns or repair guides on this. These people sell the parts and have a toll free number and may be able to assist you: http://www.ereplacementparts.com/cuisina...
Esta resposta foi útil?
Pontuação 2
You have to undo all the screws from inside and slide the outer case off there is a screw underneath a label and the front panel peel off label there should be to screw underneath at the top when you have done that there are 4 screws holding the panel on for the led circuit board I have done one my self so please put all the screws in a safe place as I did so you don't lose them I hope this helps you
Pontuação 0
2 comentários:
I hope this helps you out
por
where can you get the led display Pressure king pro 5l
por
Adicionar a sua resposta
Phillip será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Ao todo: 3,375
