Inverter cable or display cable
Following the repair instructions related to a black screen it is suggested to replace the
Inverter cable kit at $49,95, or just the data cable at $ 19,50.
Whats the big difference and why choose a much more expensive part if the less costly part will do the trick
Esta é uma boa pergunta?
1 comentário
Hello Luciano, stop worrying about the English language.
Re: your G3 iBook. +++
This sounds crazy, BUT have you tried to place the Mac on your own lap and applying a strong pressure to the back of the computer. ( for example with your knee ).
The reason for this procedure is, that some G3's had their main CPU badly or haphazardly soldered into the main board. A pressure applied even on the outside of the Mac will force the tiny soldering tips of the CPU deeply into the main board.
There is a French page giving all the dope on this procedure.
Good luck
por Hans Elfelt Bonnesen
