Ir para o conteúdo principal
sound problem after screen replacement
hi ive replaced screen on my iphone 6 i tested the phone before i plugged screen back into main body and everything worked fine. However after i put screen back into main body no sound i cant here them and they cant here me any ideas guys any help appreciated
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
I had someone a while back complain they were having a having a hard time hearing when on the phone. When I replaced the screen I missed a piece of the clear plastic protector on the front of the screen, once I removed it everything was okay.
Have you disassembled the phone and checked the connectors? Your connector for this is at the top of the phone. Make sure it is all assembled correctly. Make sure the metal prongs are connected under the bracket (not sure how to explain this. You have the metal bracket and then a black peice of ribbon cable sits on top of the microphone. On the earpiece there is 4 i believe metal prong things. They need to be sitting under the ribbon cable. The ribbon cables has spots on it that the microphone connects to. You may need to clean the connectors. Look at the ifixit guide to see how it all gets assembled correctly. Also make sure the connector is properly seated to the logic board.
I would also do a reset by holding the power and home button. While the phone is on, hold these two buttons until the Apple logo appears and then let go. See if this fixes it. If it doesn't continue on!
Have you tried switching to speaker and seeing if that works? You should also go to like Memos and make a new one and talk so it records you and see what happens. If it records you and you can hear everything fine, then its not the hardware. Do other sounds work?
You can also try going to settings and then clicking the reset all settings button and see if that helps.
Unless anyone else had any other ideas I would say you would have to do a factory reset if nothing else worked.
I think a reset or checking the assembly will fix this issue. If you do need to clean anything use 99% isopropyl alcohol. Let us know what hapoens!! Good luck!
Esta resposta foi útil?
Pontuação 0
2 comentários:
i have done all of this if i use phone with screen connected but nt inserted into main body everything is fine it only happens when i clip screen into main body
por
When the screen is on, try pushing near the microphone. All of this is on one cable so make sure it is all lined up correctly. Are all of the screws in, in the right spot? It may work when the screen is off because it can hear you better maybe? When you close the screen its kind of blocked..im not sure if that is the case or not. If you push on the screen where it is and it works then you have a bad connection. You may have a bad fkex cable as well, try moving the cable and see if it goes in and out
por
I got the same problem of bad sounf on camera selfie !and protective screen transparent film provide with new lcd was the cause of that issue on some ip 6s and ip 7 I repaired.. everything went allright after removing it ;)
Pontuação 0
I have a iPhone 7 and the sound doesn’t work on any of the apps and it’s boring because I can’t call anyone on normal call and I can’t video call on any of the apps
Pontuação 0
Adicionar a sua resposta
bob stanbridge será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 51
Duração total: 17,722
