Ir para o conteúdo principal
O Moto G 3ª Geração (também conhecido como Moto G3) é um smartphone lançado pela Motorola em julho de 2015. Ele serve como uma alternativa econômica para os smartphones carro-chefe da Motorola (Moto X). Conhecido nos EUA como XT1540, com dual SIM e versões Turbo em outros países.
89 Perguntas Visualizar todos
Why is my charger not working when phone is on and constantly charging
So I went to charge my phone and it didnt work so i tried it with another charger and it still didnt work. So i shut down my phone and when i turned it on again it said it was charging (and therefore i couldnt fully turn it on) however it wasnt on charge. I managed to turn it on once and it still wldnt charge then it shut itself down and said it was charging when it wasn't again. it will charge when it is off but not when it is on. What is wrong with it? I need to use my phone tomorrow so this is urgent!!!!!!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
well hopefully it is only a power issue. if it says it is charging while off then try to leave it off and charging for like an hour. are you using the same cord that the phone came with? sometimes these phones are finicky about the cords and charger. sometimes if you are not using the factory ones it will only get a trickle charge which is not enough to sustain it while it is on. so try to leave it on the charge for an hour while it is off and see if that helps. also try to get a better quality cord and charger and see if that also helps. i hope your issue is resolved soon
Esta resposta foi útil?
Pontuação 1
2 comentários:
Thanks. I let it die and put it on charge and it hasn't moved off 1% for an hour and it still wont turn on...
por
did you switch chargers? I have a samsung that will refuse to charge unless i use a high amperage charger and cord. I am sorry that you are going through this. try a higher quality charger and see if that works
por
Adicionar a sua resposta
sdftyuikjhgc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 194
