Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
So, any update on replacing displays?
Last I checked, about a week ago. Everyone here is saying there are errors with iPhone 7/7+. After a third party display replacement. Mostly with the home button. Which I noticed quite a few articles saying the home button messes up anyways. Also I noticed cpr saying their more than happy to do these repairs. I've been turning away and cautioning customers. Has anything changed?
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Apparently the issue is coming from people using crappy displays, and it won't read things properly. So if you just simply use quality displays, there shouldn't be an issue
por
Adicionar um comentário
2 respostas
Solução escolhida
I have just done a repair on an iphone 7 and the home button works fine, it is a very fragile part but as long as you are careful it can be removed easily. You need to push it through the front and feed the cable through and just put it back the same way in the new display assembly. The 7 is a bit more time consuming and difficult to repair than the 6 just go slow and be careful.
Esta resposta foi útil?
Pontuação 2
See the thread "Home button not working after installing new screen". Replacing the new LCD back plate with the original back plate resolves the touch ID issue
Pontuação 0
Adicionar a sua resposta
iMedic será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 712
