Ir para o conteúdo principal
4 inch display / Available in a variety of colors / Released in 3 different models / 16, 32, or 64 GB capacity
Rear camera not working , flash disabled
I have a customers iPod touch 5th. The rear camera is black. Shutter is probably not opening. It's also says the the flash is disabled until the device cools down but the device is not hot. I tried the basics of a hard reset and resetting the settings nether worked. Any ideas? Should I try to replace the camera or is that a waste of time?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
replace the rear camera, should resolve the issue for you, as the shutter may be failing, and replacing it should fix it. :-)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
AppleCrack será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 20
Ao todo: 882
