Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Perguntas Visualizar todos
I spilled coke on my Mac, everything is working.
Hi! I accidentally spilled my coke on the keyboard. everything is working fine. what should I do now? Please give me some advice. Should I just use it and forget the spills?
Thank you!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would recommend following the teardown and making sure there is no liquid on the logic board. If there is, clean this with 95%+ isopropyl.
If the liquid is confined to the keyboard only, you can try cleaning the back of the keyboard possibly. It is possible it will be fine if it is just on the keyboard, but it could possibly cause some issues with keys in future, so it may be worth doing this.
There aren't any parts available for this at the moment (other than antennas and fans), and there are no proper guides on how to open this and clean/replace the keyboard. It may just be a case of checking the logic board for liquid, reassembling and hoping for the best :)
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you so much for the advice!
por
Adicionar a sua resposta
Jason será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 749
