Ir para o conteúdo principal
Released March, 2014, features a quad-core 1.2 GHz processor, 1GB of RAM and 4GB of expandable storage.
20 Perguntas Visualizar todos
Why its showing Restore Factory Settings and Restart?
When i was using this mobile, suddenly it got switched off and now its only asking whether to Restore Factory Settings or to Restart. If we are touching Restore Factory Settings it doesnt respond. If we click Restart it will start and come to same menu as before.
Please rectify..
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If your device is running Android 5.1 or higher, your device is protected to prevent other people from using it if it's been reset to factory settings. To ensure that it's really you doing the reset, you'll need to enter a Google user name and password associated with the device after factory reset. If you don't have this information, you won't be able to finish the setup process and use the device at all after factory reset. it also one of the most like on line service, best resume writing service. if we select that one means we can get the lot information’s to our use and known about that.
Esta resposta foi útil?
Pontuação 0
1 comentário:
This device is Android Jelly bean and I have been using it from 2015. couple of days before when i was using ma mobile . It just get switched off and show its only showing this.
por
Adicionar a sua resposta
Ajithkumar B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 99
