Ir para o conteúdo principal
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Replacing front panel - problem
I tried to replace my screen everything went pretty smoothly but had an issue attaching connectors.. I powered screennon and it worked but the touch screen didn't. I went back to try and secure the connectors better. Nothing seemed to work. Not sure whatnot so can someone help?? I would even send my iPad mini screen to someone to help fix. Let me know
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I bought it from amazon. It was the digitizer. I might see if they will return and send another one
por
Adicionar um comentário
1 resposta
Solução escolhida
If it was just the LCD you replaced it sounds like you also need to replace the digitiser (front glass). If you replaced both the LCD and digitiser you may have got a defective digitiser. If you git it from a reputable source they should replace it for you without a problem.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Dawn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 56
