Ir para o conteúdo principal
Toy designed for children ages 8+ to create new crayons from old broken crayon pieces.
1 Perguntas Visualizar todos
Why unable to get any of the 6 light bulbs to work
I brought this for a Christmas gift. none of the 6 light bulbs I brought will come on.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Not familar with this item in particular but there are a few things worth checking;
Is there a fuse in the plug if so is it okay
Is the center pin in the small edison screw lamp holder free of any obstruction
Make sure the centre contact is raised enough to make good electrical contact with the lamp
If you still have an issue please check the connections to the lamp holder and that all connections to the switches and timer are sound. Also check any connections to the lid lock.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
tylersanabria será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 110
