Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Perguntas Visualizar todos
Hard Drive on MacBook Pro without touch bar
I've heard the MacBook Pro WITHOUT the touch bar uses a standard SSD that is not soldered to the mother board.
Can you advise if this is true and if the SSD could be upgraded or replaced at a later date or if it's a one time only installation.
Update (12/28/2016)
Apple MacBook Pro Core I7 15" Late 2016 specs.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Let's look a little deeper here. Is this the machine you are referring to?
Apple MacBook Pro "Core i7" 2.4 13" Late 2016 Specs
Identifiers: Late 2016 13" - BTO/CTO - MacBookPro13,1 - A1708 - 2978
por
Adicionar um comentário
2 respostas
Solução escolhida
You can replace the ssd, although it does not have a standard shape and the ssd is hard to come by. I think you can upgrade the ssd like you would on an older macbook pro.
Esta resposta foi útil?
Pontuação -1
1 comentário:
This sounds to me like an uninformed guess at best!
por
Pergunta mais útil
While this system (13" with function keys) has a removable SSD it is a custom unit.
Getting a replacement or upgrading it will be very difficult and expensive! It took OWC the only 3rd party which makes a compatible SSD unit for the older retina class systems over three years to offer one. Presently Apples SSD is faster than OWC's in the 2015 models (PCIe x2 Vs PCIe x4).
I would strongly recommend you buy the largest SSD you can afford. If you still need more storage I would go with an external SSD or HD drive via USB-C.
Update (12/28/2016)
If you're asking about the 15" model then forget it! It has soldered SSD chips to the logic board. There is no function key version of the 15" model.
Review this IFIXIT Teardown: MacBook Pro 15" Touch Bar Teardown. Jump down to Steps 8 & 9. To compare things here look at this IFIXIT teardown which is the 13" version: MacBook Pro 13" Touch Bar Teardown. Jump to Step 9 to see how its SSD chips are also soldered to the logic board as well.
Only the 13" model with function keys has a removable SSD. But again it's a custom part so only Apple can supply it big bucks $$$ and likely not available for quite sometime and only as a returnable spare.
Imagem de MacBook Pro 15" Touch Bar Late 2016
Guia
Nível de dificuldade:
Moderada
Imagem de MacBook Pro 13" Touch Bar Late 2016
Guia
Moderada
Pontuação 2
Adicionar a sua resposta
Tom Ritter será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 5,292
