Ir para o conteúdo principal
Released in October of 2014. This model, SM-G530H/DV Samsung Galaxy Grand Prime, comes in a White, Gray, or Gold casing.
148 Perguntas Visualizar todos
Why does it freeze when when I reboot it?
I turn it off completely and I turn it back on, or "reboot" it. It shows everything normally and before it fully goes to the home screen it shows Cricket. Pretty normal but then it freezes, nothing happens at all, it just stays on the Cricket screen.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Is the SIM card installed? If it is, you probably need to take it to Cricket.
por
Adicionar um comentário
1 resposta
Try booting it in safe mode. Power device on while holding volume down. once you see the Samsung logo let go of the power button, continue to hold the volume down until it brings you to your home screen. It'll say safe mode in the bottom left corner
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sureeeee será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 682
