Ir para o conteúdo principal
Support for musical holiday decorations by Mr. Christmas Inc.
20 Perguntas Visualizar todos
21 Christmas carols stopped playing
Mr Christmas Holiday Merry-Go-Round
Merry-Go-Round turns, horses go up and down, light turn on but there is no sound. 21 carols are supposed to play. I have the volume turned up on high. Received from a friend. Any help out there??
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Solução escolhida
Try to unscrew the roof, if it doesn't feel like the screw is raising up - stop turning as the shaft it is screwed to is also turning and this will twist the roof lights power wire inside the central shaft and rip the connection off the land on the circuit board below. This will also stop the motor supply. If you gently insert a wedge between the outer rim of the roof (push in that side's retaining tab), you can insert a pair of long nose pliers in and grip the central shaft, then you unscrew the top screw and remove the roof. Now you can look for broken wires.
Esta resposta foi útil?
Pontuação 3
3 comentários:
No broken wires??
por
I meant, there were no broken wires...anything else to look for?
por
Use a multimeter to test if you are getting any power to the speakers. Continue to test for continuity down to the output source.
por
Adicionar a sua resposta
K Marschel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 2,338
