Ir para o conteúdo principal
Repair guides and support for the first generation Grand Cherokee ZJ, an upscale mid-size SUV built by Chrysler's Jeep division.
48 Perguntas Visualizar todos
Why will it not set in park and 4wd not working
Any incline it rolls and front wheels have no power
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Zane Murray , Sounds like a problem with front drive shaft or axles/CV joints are bad/broken which would allow Jeep to roll and cause engagement issue to front wheels. Have a good mechanic check front shaft/ axles for fault. A worn or out of adjustment parking Pawl (inside transmission)will also allow vehicle to roll when in park. The Pawl is inside the transmission and can be adjusted fairly easily if determined to be the issue by a good technician. Attached a couple links below, 1st link is a cherokee forum that discusses the shaft/axle issue and the 2nd link talks about the parking pawl. Good luck.
http://www.cherokeeforum.com/f5/why-does...
http://myautomatictransmission.com/trans...
Esta resposta foi útil?
Pontuação 2
I have a 98, I'm still learning how things are setup on it. What it sounds like is that the transfer case is in neutral. Which would cause no drive to any wheel. Try this, start it up, put trans in N. Then move transfer case lever all the way forward to 2wD. Now see if it will move.
Let me know everything that you have done or tried along with what it's doing and when.
Pontuação 0
1 comentário:
Ok it has rear wheel but it's all time 4wd it has a popping noise kinda faint under driver seat
por
Adicionar a sua resposta
Zane Murray será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 146
