1990 Range Rover Non-functioning door lock repair
I need step-by-step directions on repairing the malfunctioning door locks on a 1990 Range Rover. Thanks for any help that might be given.
Esta é uma boa pergunta?
ronalink, Power door lock actuators replacement page 58 in the Range rover instruction manual below. Good luck.
SYMPTOM POSSIBLE CAUSE CURE
S-Central door locking does not operate (on all doors)
1. Battery discharged/ Recharge
2. Control unit in driver’s door lock actuator faulty/ Fit new unit
3. Loose or broken connection in driver’s door/ Locate and rectify
4. Blown fuse/ Rectify
T-Central door locking does not operate (on one door only)
1. Loose or broken connection/ Locate and rectify
2. Lock actuator failure/ Fit new actuator
3. Faulty lock/ Rectify
4. Mechanical linkages disconnected/ Locate and rectify
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 131
1 comentário
ronalink all door locks or a particular door? What have you checked thus far?
por oldturkey03
