Ir para o conteúdo principal
This guide contains links and information to help users repair a Craftsman 16 gallon Wet-Dry Vacuum. Model #113179930.
2 Perguntas Visualizar todos
How do I find replacement front casters for vacuum cart?
I'm trying to fix the front casters on a cart for a Craftsman 16 gallon wet/dry vacuum. The vacuum is model #113179930. Sears has a very helpful exploded view diagram for the product:
http://www.searspartsdirect.com/model-nu...
The casters I need are #23, Parts #: 73237. However, it seems they're no longer available, at least from Sears:
http://www.searspartsdirect.com/part-num...
Sears no-so-helpfully suggests: "The manufacturer no long makes this part, and there's no substitute part. If you choose to purchase a new product, please visit www.sears.com"
The current casters I believe have a completely missing roller bearing and therefore no longer will stay upright:
The casters slide into these attachments on the front of the vacuum cart:
Any advice to:
1) Find the exact replacement part
2) Find a suitable replacement I can install with the existing mounts
3) Come up with an entirely new wheel and mount system to pull wheels back on the front of the cart.
Thanks!
Esta é uma boa pergunta?
Pontuação 2
2 comentários
@luke give us some measurements. Shaft diameter and length as well as caster diameter will help us to help you:-)
por
Try www.CasterHQ.com for their grip ring stem casters. They were the cheapest online and shipped right away.
por
Adicionar um comentário
4 respostas
Solução escolhida
@luke , Luke Soules , If you have an old caster assy. take it with you to hardware/surplus store to compare with what they have in stock as they may have a replacement. Posted a few links below for replacement stem casters. Good luck.
http://www.homedepot.com/b/Search/N-5yc1...
https://casterconnection.com/casters/ste...
http://www.faultlesscaster.com/page.php?...
Esta resposta foi útil?
Pontuação 5
Hey luke, the cheapest casters I have found are from source 4, and they also have a guide for measuring them to know you're getting the right one:
https://source4industries.com/blog/how-t...
Pontuação 1
Hey Luke,
Checkout this link to CasterHQ, they have a huge selection of 7/16” grip ring casters available with different wheel materials.
https://www.casterhq.com/Grip-Ring-Stem-...
Pontuação 0
Hi Luke,
I guess this is an old post, but I rebuilt my vacuum with wheels from www.castercity.com
Better than amazon, but a little more expensive.
Pontuação 0
Adicionar a sua resposta
Luke Soules será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 21
Duração total: 712
