Ir para o conteúdo principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
purble line on screen
I have a Samsung S-7 edge in less than two months of use, vertical purple line on the screen appeared. Screen replaced with a new one, and after less than a month the same line back in the same place. I tried to repair by clicking on the cable behind the screen where the light pressure when the line disappears. But I messed up the work of the screen entirely. The problem I am afraid that the screen was replaced and spent the money and then break down again. Any useful answer be gratefulbold text
Esta é uma boa pergunta?
Pontuação 2
1 comentário
Did you check your warranty before you replaced the screen?
por
Adicionar um comentário
2 respostas
Solução escolhida
Sounds to me like the digitizer connector socket has been damaged. It'll need to be replaced with a new one. You can try iPad Rehab. They do excellent work
Esta resposta foi útil?
Pontuação 1
1 comentário:
thanks bro i will try
por
Pergunta mais útil
Try Pixel Fixer from PlayStore
http://play.google.com/store/apps/detail...
Pontuação 2
Adicionar a sua resposta
azaran2006 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 3,747
