Replacing the drivers window because the attachment Clips are broken o
How to remove the passenger side window and then replace it
Esta é uma boa pergunta?
@jesscuz , Jessica, Broken plastic window mounts. Video below will show at approx. 4.30 mark the bolts that need removed to enable window removal and install. This is the driver side window but pretty much generic to the passenger side. Good luck.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 164
1 comentário
@jesscuz not sure which attachment clips you are referring to.
Rep: 1
por oldturkey03
