Ir para o conteúdo principal
Released June 2016, identified by model number A3003 in Europe, A3000 in China and North America (according to https://forums.oneplus.net/threads/oneplus-3-regions-model-numbers.452381/)
Power button oneplus 3/3T
Hello. I would like a tutorial on how to repair buton power? And if it is a power buton that will break easily?
Because on my moto G 1st Gen my buton power broke, but I can not repair it because I need to do micro welding. So I want to know if it is the same or if it will break easily as on my moto G.
Thank!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
According to the oneplus 3 teardown work, it seems that the power button can be removed once the screen assembly is separated from the rear housing , it's not soldered to the rear housing or glued to the rear housing, you can just remove it easily.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Gabriel BEck será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 14
Ao todo: 1,648
