Ir para o conteúdo principal
20-inch, 23-inch, and 30-inch aluminum LCD displays introduced by Apple in June 2004. Models A1081, A1082, and A1083 respectively.
99 Perguntas Visualizar todos
How to connect a cinema display to a MacBook?
Hi everybody!
This is my problem: can i connect an Apple Cinema Display (year 2008) with a Macbook Pro (year 2010)?
Thanks a lot
Leonardo
Esta é uma boa pergunta?
Pontuação 1
2 comentários
Please give us the model number located on the bottom of the stand.
por
You would need a DVI to Thunderbolt adapter. Does your MBP have a FireWire port on it?
por
Adicionar um comentário
2 respostas
Solução escolhida
Apple sell a DVI to Mini Display Port (AKA Thunderbolt) adapter. This is the one I use now and it is very good. I have bought a third -party adapter before and it was really bad: loose fit, colored edges artifacts, and finally no video whatsoever. You get what you pay for, as the saying goes..
Esta resposta foi útil?
Pontuação 1
For the 20-inch or 23-inch Cinema Display:
You need the Apple Mini DisplayPort to DVI Adapter pictured here (or a third-party equivalent).
For the 30-inch Cinema Display
You need the Apple Mini DisplayPort to Dual-Link DVI Adapter shown below. (There is no third-party equivalent as far as I’m aware.)
Apple no longer sells either of these adapters, but they can be found on sites like eBay and Amazon.
Pontuação 1
Adicionar a sua resposta
Leonardo Ferri será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 1,061
